Plug and Play replacement for PCI-MIO-16E-4
I am upgrading to windows 7 all the way from XP. My PCI-MIO-16E-4 is no longer supported. What is my best bet as a replacement so I continue to use my current vi .
(2,644 Views)
Based on what crossrulz found, both your hardware and your vi are going to be obsolete.
You'll need to convert to DAQmx in order to work with Windows7.
What are you using the MIO for now?
The X series DAQ cards are pretty good. If you only need lightweight use, the USB-6008 may be an option.
(2,634 Views)
