Plot/print data in a VI while this data is updated in a CIN
Is there any chance to constantly update data inside a CIN while displaying
this data in a VI at
the same time? I know that I have to run the calling VI of the CIN code in a
different execution thread than the VI
for displaying the data. But how can I exchange data with a CIN whithout
ending the execution of the CIN.
Can I pass a Named Queue or a Notifier to a CIN?
Klaus Staehle
Heilbronn
Germany
-**** Posted from RemarQ, http://www.remarq.com/?a ****-
Search and Read Usenet Discussions in your Browser - FREE -
(1,347 Views)
There are probably several ways to do this, but by far the
easiest would be to treat the CIN as a function call that
returns and is called again with new data. If you want to
have some constantly running code that blocks on a mutex or
a semaphore, then spawn that code the first time you need
it in the CIN, and keep it running in your own thread.
Now the CIN enters, drops off the d
ata in whatever structure
you decide to use, and exits to get more data and return.
Meanwhile the background thread can execute however you like
and the only synchronization needed is a way to spawn it, a
way to mutex the data dropoff, and a way to tell it to exit.
The background C routine that you spawn or fork is now totally
independent of LV and could be used anywhere. The CIN portion
is particular to LV, and is lightweight.
This of course is easy only if you know how to do it in C or C++.
The easier route is simply to place the work in the CIN, spawn
nothing, and let the diagram and CIN take turns. This approach
is less sophisticated, but can be made to work quite well for
a fraction of the effort.
Greg McKaskle
(1,347 Views)
