Plot a graph with the value distribution in percent
Is there an easy option to plot a graph with the value distribution in percent. I want to get something similar to in the picture. If I try to make myself, it will be big and chaos. Thanks
Message 1 of 12
(2,932 Views)
You can change the format of the markers accordingly, e.g. "%.0f%%" (use the advanced formatting option)
Message 2 of 12
(2,930 Views)
Here's one possibility....
Message 3 of 12
(2,926 Views)
These are the rms of weighted values. I have to show the percentage of each value from the list. I was thinking maybe there is a built-in function which is like histogram, but more specific to my need, then I don't have to program it.
Message 4 of 12
(2,889 Views)
Well, your problem description was not clear at all, because I took it as a cosmetic problem. To calculate a normalized integral, that would be an easy data operation. Start by attaching some simple data.
Message 5 of 12
(2,885 Views)
See if this can give you some ideas....
Message 6 of 12
(2,875 Views)
That's exactly what I need, but the code isn't quite clear. Could you please elaborate or upload an example if don't mind.
Message 7 of 12
(2,862 Views)
Well, there is a built in function like that.  Surprisingly it is titled Histogram.vi
Altenbachs code is simply faster.
"Should be" isn't "Is" -Jay
Message 8 of 12
(2,849 Views)
Altenbachs code is simply an extremely efficient way to scale and sum the counts of the bin outputs after passing the raw values through a histogram.
Message 9 of 12
(2,846 Views)
The quality of my answer cannot be significantly better than the quality of the question (well, sometime I guess right and it is!).
Apparently, you have several analysis steps:
  1. Calculating a histogram of the raw data
  2. calculating the integral of the histogram
  3. Graphing both 1&2
  4. Displaying the axis markers containing a percentage sign.
Initially, I thought you needed help with #4. Later I added a solution for 2&3, still assuming that you already have the histogram data. Now you are telling me that you also need help with #1. Who could have guessed!!!
I have asked you to attach some typical data, which you did not do, but would have cleared things up. I am not clairvoyant! Once you decide to attach some data, I will attach the full solution. Until then, it is a waste of my time to keep guessing what your problem really is.
Yes, LabVIEW has built-in functions to calculate histograms, but I would recommend an even simpler solution. What is the data range (0 to 0.1??)? How many bins do you want (100?)? Do you also need a bin for values that are outside the range? No matter what, the code is trivial and probably fits on a postage stamp. 😄
Message 10 of 12
(2,837 Views)
