Plot Power spectral density of a signal from myDAQ.
I need to plot the power spectrum of a signal acquired using myDAQ. I have already been able to acquire and plot the input signal. The example given in Labview for power spectrum uses a pre-defined sine wave and replacing the sine wave by the input signal does not get the work done..
Please Help...
Message 1 of 8
(5,578 Views)
Why have the second loop?  Looks like you should have what you want with just the first loop.  Here's a cleaned up version of your code.  I only removed the second loop and then did some slight rearranging to make it easier to read.
Message 2 of 8
(5,566 Views)
This part worked fine for me as well. But the problem I was getting was that the graph for power spectrum was limited to 500Hz only, despite changing the range for the axis..
Thanks a lot for helping
Message 3 of 8
(5,538 Views)
Accepted by bns2804
That's because you are sampling at 1kHz (1000Hz).  Remeber Nyquist (you must sample a signal at at least twice its bandwidth)?  So your FFD will only go up to 1/2 of your sampling rate.
Message 4 of 8
(5,536 Views)
Oh! That didn't come to my mind.
Thanks a million !
Message 5 of 8
(5,527 Views)
I have two question to ask you, the first is how to generate continuous power spectrum density on one graph and how to save the RMS value on Labview, am having a problem with saving due to its being a cluster and it is not compatible with any of the storage function. Any hint will be fine
Message 6 of 8
(4,616 Views)
Hey Philip_97,
It looks like you posted your question to a thread that is over 3 years old.
This thread already has a post marked as a solution.
This question should become a new thread in the LabVIEW section.
It would also be very helpful if you could add pictures of your code and any hardware information.
Salil Pathare
Applications Engineer
support@ni.com
Message 7 of 8
(4,602 Views)
I have two question, is there a way to have all your power spectrum  sample measurements on one graph ( an example is the attachment capture example below)on LabVIEWNXG and secondly, is there a  way to save the RMS data ( which is a cluster which contains three elements) as a file , I have tried all storage function in LabVIEW NXG and none has worked with it . hope you can provide a hint.
Message 8 of 8
(4,595 Views)
