Please help to automatically print the coordinates on the drawn line
Hello, if you look at the vi I made, there are lines from (0,0) to various concentric circles, can you make the coordinates of the points that touch the circle automatically come out?
(1,957 Views)
Can you define the meaning of "come out"?
Sorry, cannot look at your code at the moment. Consider saving for previous (LabVIEW 2020 or below) before attaching.
(1,910 Views)
I looked at your code.
It's very sloppy.
So I stopped looking at it.
(1,856 Views)
OK, I had a chance to look at your code, and has has been mentioned, it is extremely convoluted.
  • The terminals of latch action booleans belong inside their respective frames.
  • All your shift registers are equivalent to autoindexing, so simplify!
  • There is an "=0" primitive.
  • Your formula node should be replaced by G code. There are many subexpressions that you calculate multiple times.
  • There are significantly easier ways to calculate circles.
  • Your insert into array are the same as built array(concatenate mode). No need to wire indices.
  • You can build your data as complex datatype. No need for dynamic data and express VIs.
  • To create gaps in graphs, insert a point with NaN.
  • etc.
I have problems with my VM locking up, so please "save for previous (2020 or below)" and attach again.
(1,823 Views)
your original .vi is indeed a bit messy, but when I run your .vi, it creates data in a XY Graph.
the following is focusing on that data in the XY Graph, because I think it would be easier to start over again, than to rework your existing code.
I assume
you want this but the data your .vi creates, looks like this
(1,813 Views)
