04-30-2008 09:29 AM
04-30-2008 10:40 AM
04-30-2008 11:30 AM
04-30-2008 11:47 AM
05-02-2008 09:40 AM
Hello TWGomez,
finally i got it, that it plays in the size of the container.
But, of course it is Friday and of course i have now another problem: If i press a button on the controls (pause, stop) the movie enlarges, and it also enlarges, if the Vi is still running but the movie has end. Do you have the same "feature"?
Maybe this all could be a problem, because I am using LV 8.0, but on the other hand, it is only a question of the used active X libary and the media player version. I am going to try the 8.5 evaluation version over the weekend, to see if there is any difference...
One strange thing is, that if i use "stop" to stop the video after stopping the VI, the movie starts next time again in the contianer size. If i use "close" to stop the video, i have to minimize the movie under the specified size with the mouse before starting the VI and than it plays in container size, otherwise it is again enlarged...
Thanks a lot for your patience, it helped a lot!
Lord Chaos
05-02-2008 09:50 AM
05-07-2010 05:01 AM
hello sir,
i,m using labview 8.5
i had seen those image that are attach with the example code
and i did exactly what, is mention in it
but at last i cant find container bounds of windows media player, so i cant get the result
more over, when i run the vi it ask me the path of video path(that i had alrady mention)
and after that a error 42 dilog box apper....ask for STOP
so i cant run the vi
plz send me a solution on my id:dhptl_ni@ymail.com
