Pick up from where I quit last time from a LabVIEW appliaction
Is there an easy way that I can dump the current state of a Labview program/application into a "memory dump" file before I quit the program, so when I restart this LabVIEW application, it restores the info from this "memory dump" file, so I can pick up where I left off exactely?
Thanks.
Ian
Message 1 of 10
(4,434 Views)
You can use INI files or XML files to store the current state of the front panel controls and then during the loading phase of the app, if a file exists, load the values into the appropriate controls and delete the file.
aputman
Message 2 of 10
(4,420 Views)
aputman
Thank you for your input. I am not sure if we are talking about the same method, but I found the following that can work for me.
It sets all controls to their last states only, it does not set indicators to their last states. I think I can live with it.
https://forums.ni.com/t5/Example-Code/Programmatically-saving-and-loading-values-of-all-front-panel/...
Thanks again.
Ian
Message 3 of 10
(4,400 Views)
aputman was answering your question. He is saying that you can programmatically save the values of your controls, as well as any other state information you may need to a file. When the application starts it loads the files, resets everything to the satet and resumes execution. If you are using a state machine you can literally pick up where you left off in your state machine. Unless everything you are using in your VI is a control your method will not be able to resume with everything reset to its last value. Only control values will be initialized.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 10
(4,391 Views)
Mark/aputman
Thanks. Can you attach a simple example to elabrate?
On the method I found, I realized if I set "Controls" to "false", I can save and then load and reset values for all indicators too.
Ian
Message 5 of 10
(4,382 Views)
Here is an example of how I usually do saving/loading of configuration data. It uses the MGI RWA (Read Write Anything) library which you can download for free. Just go to VI Package Manager and search for MGI RWA, and install it.
--Hope
Message 6 of 10
(4,368 Views)
Just realized you may not have 2016 yet. I backsaved it to 2014, hopefully that works for you.
Message 7 of 10
(4,365 Views)
OpenG library has a VI called "Write Panel to INI".  It's in the Variant Configuration File palette.
aputman
Message 8 of 10
(4,324 Views)
Oops. I just read your post above with the link to the article about CtrlVal.GetAll.  Yes, that is the method that OpenG VI uses.  It will also write indicator values.
aputman
Message 9 of 10
(4,321 Views)
aputman
Many thanks.
Ian
Message 10 of 10
(4,302 Views)
