05-21-2010 08:43 AM
Bonjour,
Peut changer un control en indicateur de manière dynamique ?
Cordialement
05-21-2010 08:45 AM
05-21-2010 09:08 AM
05-21-2010 09:39 AM
I'm pretty sure you can't:
in fact you would change run time the execution flow of the program....
What you can do is "disable" the control run time and use it through local variables and property nodes.
In this way the control is acting as an indicator (but remaining a control).
You can than re-enable it when you want (again run time).
Marco
05-21-2010 12:04 PM
Vous pouver changer une valeur de control dynamiquement avec un "Value Property Node"
