Peak Detection for XY graph
I have already collected an array data with X and Y values.  I have plotted that data on an XY graph and interested in getting the peaks and their locations.  When using the Peak Detector.vi, I can get the peaks by feeding in the Y values from the array, but of course the X data will not be plotted to give me the locations.  How can I add my X values to the peak detector as it is only giving me the locations with repect to time.
Thanks.
(4,109 Views)
try something along the lines of this
- there is always an easy way, but it is always the hardest to find
(4,097 Views)
can you please save for version 8.0. Thanks.
(4,095 Views)
here
(4,092 Views)
thanks for the quick help beaton.
the problem i have is that my data is not a waveform, but simply x and y points.  In you have a chance to look at my program, frame 2 has my X and Y seperated to graph in my XYGRAPH and the next frame is used to find the peaks of that graph.
(4,089 Views)
