10-01-2008 04:37 PM
I haven't used LabView for a number of years and forgot way too much. I'm trying to create a simple task for a VI and not having any luck.
I am using a FOR LOOP and need to pass different parameters to an instrument with each index count. I will use four counts and I have three parameters to pass for each count. The parameters are known and constant. I need to be able to load the paremeters into a structure and then pipe each out to three different functions.
It seems so simple but I haven't found a way to do this.
Thanks in advance
- Bill
10-01-2008 04:41 PM - edited 10-01-2008 04:42 PM
One easy way to do this is to wire the for loop iteration count to a case structure (wire directly to case terminal, and create a case for each iteration). For this to work you have to know ahead of time how many iterations you will have, what each one will do, and preferably the same data type for each parameter, perhaps a string.
(What part of Colorado are you in? I'm in Fort Collins. Just curious who else is using LabVIEW in my neck of the woods)
Jon
10-01-2008 05:14 PM
Hi Jon -
Thanks for the prompt and very good advice.
(I'm just outside of Boulder enjoying the beautiful fall weather)
Cheers!
- Bill
10-01-2008 05:17 PM
