Pass listbox NAMES to subVI
In the attached main VI (main2sub), how do I going about passing the names of the listboxes from the MIAN VI to the the subVI?
hiNI
Message 1 of 8
(4,549 Views)
Use the ItemNames Property.
mcduff
Message 2 of 8
(4,519 Views)
Do you have to unbundle then bundle each element in the cluster then pass that to the subVI?
Thanks.
Message 3 of 8
(4,507 Views)
The names come out as an array of strings.
You can pass the array directly into your subVI, or you can pass a reference from the listbox to your subVI and use the property ItemNames in the subVI.
Maybe you can better explain what you want. A listbox may not be the correct control, maybe just use an array instead.
mcduff
mcduff
Message 4 of 8
(4,503 Views)
The premise is that this listbox is used as a selection box for inputs into the subVI.  This listbox is created from parsing repeated data.  Each new dataset creates an input into the listbox.  After the listbox is created, I can then go and select one or more input to generate plot data.  Here is a screenshot of my main VI:
I can then go and select one or more rows from either the "Temp", "Test Condition" or "LO Freq" and the idea is to get the plots accordingly...
I tried this option:
but could not get the names to appear in the subVI.
Is there a way to have the full cluster pass through to the subVI?
Message 5 of 8
(4,449 Views)
Hi hiNI,
I tried this option: but could not get the names to appear in the subVI.
- You already wire the "full" cluster to the subVI - why use an additional reference too?
- When you use a reference for the cluster you need to read the cluster element references first. Use them to read the content of those listboxes…
Message 6 of 8
(4,444 Views)
Accepted by topic author hiNI
No, listboxes do not pass the names.
You can try something like this.
 Edit: GerdW beat me with words.
Message 7 of 8
(4,443 Views)
You might also be interested in going through the list of selected items, and only returning the ones the user choose, and only pass that into the subVI.
Also if you are looking for allowing a user to select multiple items from a listbox, I would suggest you look into some code I posted here, which allows for item selection by clicking checkboxes in a listbox, multicolumn listbox, or tree.  What is returned is the array of items selected as tags.
Message 8 of 8
(4,434 Views)
