04-28-2021 06:02 AM
Hello at all an please forgive my English language, the English language are not my native language.
Why "Particularly / unusual approach for two machine vision cameras" ?! Seems that on internet I do not find same approach for my needs. This approach are made it usually with an optical "Beam Combiner", a "Mirror" and one analog / digital camera.
Well... I need it to made it completely digital / software controlled. Why ?! Well... Due to long distance camera focusing distance !
Let start with what I need. I need acquire two real time images / videos from 2 separate USB cameras. One camera look at one object, second camera look to another object. The shape, patterns, dimensions of two object are egal. In fact are a matrix of points (circle). Let say... 5 points on a square shape objects.
The objects are on Z axis one let say at 0mm and another object at 100mm on top of first. What I need is look with a camera at object from top and see the 5 points, look with another camera at bottom object and see the 5 points and move the bottom object on X and Y axis to center / align the points / circle from top object with the points from bottom object.
The application will be used to align a BGA Chip balls with corresponding PCB pads. For exemplify this I put here a link to a video... https://www.youtube.com/watch?v=0KN8z3OhiAM at minute 1:40 you can see the real live process to center a BGA with corresponding pads.
This analog method mix with a beam combiner prism and a mirror two sided images and capture on a CCD analogic camera.
This analog system have many bad proprieties, major bad thing is the physicals volume / dimensions that have this system, large optical focal distance (that make the BGA and PCB to be a large distance one from another and generate small alignment precision), high price (due to optical sistem that are not cheap) and so on.
I bet that in LabView it can be mixed (overlaid) two video from 2 camera but I have no ideea how ! The truth is that I don't start experimenting for the moment but... I need some ideas from where can I start experimenting.
07-06-2021 12:37 AM
Did you find the answers of your task?
07-06-2021 03:45 AM
No, I don't find any answer yet and for the moment I have no time to experiment with this task, seems that will be a... long story. But I'm convinced that is possible.
Best regards, Marcelo
