Parallel and serial port input at the same time
I want to acquire 2 different signals from 2 different sensors; and i want to process theese 2 different signals as inputs at the same time in labview.
Can i use parallel and serial ports as inputs at the same time?
(2,076 Views)
The simple answer is yes. The serial port can be communicating in one loop while the parallel port is being used in another.
P.M
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,072 Views)
