05-06-2026 10:40 AM
I generally try to avoid .VIT files, they give me more headaches then they solve.
Here is a minimal working example showing subpanels in subpanels, using regular VIs.
Make sure to set any VI you want to run in parallel to Shared Clone Reentrant Execution.
Then call them with Start Asynchronous Call, with the 0x80 (Call and Forget) flag. No need for the 0x40 shared pool flag.
Make sure to add a way for the caller to stop the called VIs. Here I use User Events, but that depends on your architecture.
Hope it helps.
05-06-2026 11:28 AM - edited 05-06-2026 11:30 AM
@thomas-allibe wrote:
Ah yes, including links (clickable or not) will delete the message....
WITHOUT WARNING!!!!!!!!!!!!!!!!!!
The forum software has been super janky for the last month or so. Attachments have been coming and going randomly, and it looks like links are being weird too. Links are definitely allowed in a general sense- there are a couple filters here and there (I think F@cebook isn't allowed?) but by and large most stuff is allowed.
(It's not just you ☹️)
05-07-2026 02:40 AM - edited 05-07-2026 02:43 AM
Hope it helps.
Ah yes, I didn't think about calling "Open VI Reference" on every iteration. I guess it allows you to not use 0x40 flag and directly use the vi reference for the subpanel "Insert VI" node. Which is simpler that what I suggested, but is (I suppose) slower since you open the reference multiple times, but it probably doesn't matter.
05-07-2026 02:42 AM
Yeah I saw people complaining about attachement issues...
It turns out my supposedly deleted messages have all showed up later in the replies😅
