09-19-2014 04:52 AM
Hi!
I am new in the community, so "Hi everybody!" and thanks for your help
My problem: I have a scientific camera that has its own drivers and VI's for Labview. I have installed the camera properly, and I have already created a folder and copied the .llb archives on it.
When I open any of the examples to start working with it, I can see in the palette view, in the user controls, my folder. But inside the folder there is nothing. I can not find the llb's or VI's that I expected.
I have tried to go to Advanced/Edit Palette Set, but I don't know what to do, because I can find there all the .llb and VI's. so it seems that everything is correct. But it is not, because I can't see any of them in the normal palette view.
Can sby tell me what am I mising? There should be sth that I haven't done correctly, but I don't know what.
Thanks!
09-19-2014 07:29 AM
Hey, welcome to the forums
The sets of Vis and llbs for your camera are known as an Instrument Driver. You have to extract these to a specific location so that LabVIEW can update the pallet sets using .mnu files included in the driver files.
The location is C:\Program Files\National Instruments\LabVIEW 2014\instr.lib\
Try moving your files there and then restarting LabVIEW.
This Knowledge Base article may also be useful for you:
http://digital.ni.com/public.nsf/allkb/86256F0E001DA9FD86256F0B0057E6E7
The following white paper discusses how to modify, build and install .mnu files to add/modify the current palette set.
http://www.ni.com/tutorial/14528/en/
Cheers
09-19-2014 07:43 AM
Hi tim.h,
thanks for your help.
I already knew the first of the links.
I will check the second one. But not now, cause I'm off for the weekend! 🙂
Enjoy it!
I will let you know if I get it work with that link.
Thanks again,
Akuandi
09-22-2014 09:32 AM
Hi Tim!
Thanks for your help. It is already running!
