PXie 7976 Clock generation
I am trying to use my flexRio to generate essentially an 80MHz clock. I created multiple versions to test and try to find the best clock.
I tried creating a clip as well as just a vi. For some reason, both generate an 80 MHz clock +/- .4MHz, but from looking at the datasheet, it should be able to generate a much better 80MHz signal.
My vhdl code is essentially this where count_M80 is a counter from 0 to M80, M80 is 0 to 1 (since my clock is 160MHz and with 50% duty cycle, 160/80*.5 = 1), and register_m80 is just a std logic and connected to my output.
	begin
		if rising_edge(clock) then
			if count_M80 = M80-1 then
				register_M80 <= not register_M80;
				count_M80 <= 0;
			else
				count_M80 <= count_M80+1;
			end if;
		end if;
	end process tutorial;
 I tried the below to generate an 80MHz clock too by having the below in a 160MHz timed loop.
Shouldn't my clock output be a lot more stable? I have the clock connected to PXIe_DstarC and have a ni-sync vi to measure it.
Message 1 of 9
(2,290 Views)
It looks like your are using a NAND with a True to toggle the boolean.
Wouldn't it make more sense to just use a NOT?
Message 2 of 9
(2,257 Views)
It makes no difference. I have one version where I'm using a NOT gate and its just as volatile/unstable. I just didn't want to post essentially the same picture but with a different gate. My apologies.
Message 3 of 9
(2,238 Views)
Will this clock be interfaced with an I/O pin?
Asking because I rarely see such an implementation in LabVIEW FPGA since we typically derive clocks from the base clock(s).
ALE Consultants
Message 4 of 9
(2,224 Views)
Update, Ive even tried all these to get essentially the same result
https://forums.ni.com/t5/Example-Code/Export-a-Clock-Signal-on-FPGA-Device/ta-p/3530075?profile.lang...
Message 5 of 9
(2,219 Views)
Ideally this would be sent to the DStarC line and then outputted through a timing card.
Message 6 of 9
(2,217 Views)
That's an older (2010) document; I'd look for something more recent.
It is for DAQ cards but this may help: https://www.ni.com/en-us/support/documentation/supplemental/10/synchronization-explained.html
ALE Consultants
Message 7 of 9
(2,213 Views)
So I believe I am doing what they recommend (Using the DStarC lines since im going from FPGA to timing card which is considered the best). It says I should expect about <500 ps of skew, but when I'm measuring it, im off by like 400 KHz which doesnt seem to make sense, unless its potentially from the ni-sync measure frequency accuracy? I've used the measure frequency vi prior and it was pretty accurate prior. I don't imagine the DStarC line to be that noisy or cause that much jitter?
Message 8 of 9
(2,209 Views)
Not sure what else to recommend.  May be good to reach out directly to NI support.
ALE Consultants
Message 9 of 9
(2,204 Views)
