I have this query regarding PXIe-6366, multi function DAQ. It has 2 AO channels, 8 differential AI channels and 24 DIO. Now,
(i) In MatLAB I have generated a .mat file having 15000 samples of doubles.
(ii) And I have a separate digital to analog converter board that I wish to communicate with using DIO pins of the PXIe-6366.
Basically I want to transmit that .mat file to my digital to analog converter board using 19 DO pins on a clock frequency of 8 MHz. And then the using 4 DI pins I want to receive data from the converter board. Now I know that DIO pins are individually programmable. And it has 10 MHz DO clock frequency. But I can't seem to display the clock frequency mentioned. How to generate and use it? Is this whole setup feasible?
