Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
11-21-2018 03:50 AM
i want to sink 10mA current generate at 100kHz rate as a clock.
Is this frequency achievable with PXIe-4143?
I understand i should use sequence mode, any VI example to share?
i've found one where there was a 5kHz limit set, is it due to hardware limitation?
thanks ,
Nicolas
11-26-2018 06:57 AM
Hello NicolasRobin,
According to the specifications of your device (http://www.ni.com/pdf/manuals/376109b.pdf), you can sink 10mA current.
Is the example you have found directly related to the PXIe-4143?
Armando
Thanks!
We'll be in touch soon!
