04-17-2019 07:08 PM
I'm getting started with a PXIe-4141 SMU (on LV 2018).
While measuring a single channel works fine, using multiple channels fails as some properties can't be set if a session contains more than 1 channel. Looking at some multi-channel examples for NI DCPower, they use a seemingly cumbersome master/slave configuration. Is there no simple way to setup all 4 channels with one common session and measure/fetch a fixed number of points?
I would assume that this is one of the most common workflows with the SMU, to define the number of points (this property can't be set for all channels at once) and then sense all channels. How do you use the measure multiple channels vi, as I did not see it used in an example? Sorry I don't have my current code attached as it's not easy to get it out of the lab. Any help or pointer in the right direction would be really appreciated.
Cheers
Sebastoa
Solved! Go to Solution.
04-18-2019 10:02 AM
Hi Sebastoa,
Have you checked out the NI-DCPower Simultaneous Operations example? It shows how to use the Measure Multiple.vi.
04-18-2019 11:46 AM
Hi Luke,
thanks, I missed that example, was looking at the synchronous examples instead.
What I didn't realize is that the 'init with channels' doesn't need channel(s) passed (the names kinda suggest it does), now the flow really makes sense.
Cheers
