I was able to accomplish what your talking about using an e series board,
I think. I set up the counter as in the generate continuos pulse train example,
and then added a Get Attribute in the loop and monitored the output state.
I used a shift register to tell if the current state equalled the previous
state, when false I generated an occurence in a case structure. In a separate
loop I waited on the occurence and turned a boolean on and off with each
transition of the counter. I hope this what you were talking about.
mark.wysong@ae.ge.com wrote:
>I have an application where I would like to set an occurrence when the>output
of one of my general purpose counters changes state (I don't>care which state)
on my PXI-6070E. Is this possible?>>I know you can set occurrences with
the DAQ occurrence VI, and I've>successfully done it with analog acquisitions,
but I really need to do>it with the counter.>>Mark>>>Sent via Deja.com http://www.deja.com/>Before
you buy.
