02-22-2010 03:47 PM
I am triggering a 5122 from an FPGA card using a PXI trigger line. The 5122 appears to never trigger (no data ever returned). I replaced the PXI trigger with an external trigger from the FPGA and it works fine. I tried several different lines and none work. Am I missing something?
TIA,
Bill F
02-23-2010 02:19 PM
Bill,
Do you have any other cards in your PXI chassis that you could use to try to trigger the 5122? Or a different card to try to trigger with the FPGA card. Those would be two things to try. Also, see if switching slots in the chassis makes any difference.
-Christina
