I am using NI PXI-1045 chassis with NI PXI-8196 Embedded Controller.while configuring NI PXI Chassis, i am getting an error "This chassis has been identified but it is not describedin the pxisys.ini for this sytem"
Move the pxisys.ini. and pxiesys.ini to the desktop or rename them. (For example, you could rename pxisys.ini to pxisys_old.ini.) You may only have pxisys.ini or pxiesys.ini.
Restart the PC and launch MAX. This will cause PXI Platform Services to find the installed devices again and also recreate the pxisys.ini and pxiesys.ini files.
On a PXI Real-Time (RT) System or Dual Boot PXI Controller, you will need to remove the pxisys.ini file from the /NI-RT/SYSTEM/ folder. You can do this by doing the following:
