07-11-2014 04:44 AM
I have PXI 8252 1394 Host Adapter in my PXI 1000B chassis. PXI is controlled using MXI-3 fiber optical communication.
NI PXI 8252 is not seen in MAX.
I want to program the 8252 using LabVIEW but it is not seen in MAX.
Thanking You
Kiran Patel
07-11-2014 05:15 AM
Are you able to see the PXI chassis in MAX?
07-11-2014 05:46 AM
First you need to add chassis and then modules to it. If you are not able to locate chassis then drivers are not installed for PXI
