PXI 6683H
First, please open the following web.
http://www.ni.com/tutorial/53115/en/.
When I went to step 4 based on this post,I met a question.
I did not find the Oscillator and  PXI_Clk10 in the source.I also did not find the ClkOut and  BoardClk in the Destination.
Thank you very much.
(2,190 Views)
Did you complete the step below?
Single-Board Disciplining with the PXI-6683H: Since the PXI-6683H is a hybrid card and does not fit in the timing slot of the chassis, it cannot override the chassis’ backplane directly. Instead, you will need to externally cable the disciplined on-board oscillator of the PXI-6683H to the 10 MHz Ref In connector on the chassis. (Consult your chassis’ user manual to ensure your chassis has a 10 MHz Ref In). To do this, complete the following steps:
  • Using an SMB to BNC cable, connect the CLKOUT terminal of the PXI-6683H to the 10 MHz Ref In of the chassis.
  • Either in the Routing tab of a MAX test panel or by using the niSync Connect Clock Terminals VI in LabVIEW, make the following routes:
    • Source: Oscillator; Destination: ClkOut
    • Source: PXI_Clk10; Destination: BoardClk
(2,154 Views)
That doesn't fix it.
(505 Views)
The NI-sync API has two similar name VIs.
The article is using the former. So, you might want to check that.
-Tyler
(485 Views)
I guess I'm misunderstood.  I don't have access to Labview.  How do you get the Oscillator and CLKOUT to show up in the NIMAX test panels.
(449 Views)
