Reply
PXI-4472 compatibility NIDAQmx base 3.4.0
I have labview 10.0 in opensuse 11.4 and apparently there is no NIDAQmx support for labview 10.0 so I ended up installing the NIDAQmx base 3.4.0.
I have a PXI-4472 card and it is not detected with the apparent reason that the NIDAQmx base.does not support the PXI-4472.
Is there someone who has had a similar problem and is there any solution of working around this issue?
Please let me know,
Chiran
(248 Views)
Re: PXI-4472 compatibility NIDAQmx base 3.4.0
(241 Views)
