Reply
PWM Update Rate using PXI 7334 & 6602 cards
I have a NI 8176 controller and a PXI 7334 (FlexMotion) Motion Controller Card. I am using the PWM output to control an actuator and I would like to update the duty-cycle as frequently as possible.
I have the card PWM frequency set to 32 kHz, but can only achieve 1.5 kHz update rate.
The attached VI shows the code I'm using to write to the card.
I also have a PXI 6602 card, I can achieve an update rate of 6.5 kHz with that, but I bought the 7334 card with the expectation of achieving a faster update rate.
Any advice on how to improve the update rate of either card would be appreciated. Likewise, does anyone know another hardware set-up that would be a viable alternative?
Many thanks,
Brian
(872 Views)
Re: PWM Update Rate using PXI 7334 & 6602 cards
You may want to try this firm ware update which will let you use the PWM output of the 7344 as if it were a servo axis. I believe this may give you the faster control you are looking for.
Regards
Amaury
NI Application Engineer
(872 Views)
Thanks Amaury,
I went to:
Support > Product Reference > Drivers and Updates > Current Versions - Motion Control > NIMotion/Flexmotion Version 5.2 for windows 2000/95/98/ME/NT/XP
I have successfully upgraded my firmware. I now need example code to show how the PWM output can be updated as if it were a servo axis.
At the moment, using the code posted above, updating just 1 channel, I can only manage an update rate of just 3.6 kHz.
Brian
(872 Views)
Sorry to take so long Brain, I was just looking through some old posts and noticed that I had never given you the firmware you actually needed!
Try this!
(872 Views)
Hi Amaury, thanks for the fp2 file, I’ve just moved site, got my lab back yesterday. (please watch the numbers 7344 and 7334 in the text below!)
The FPGA2 firmware I had was Version 5.20.0001, MAX would not allow me to select the file 7344pwm.fp2, I got the message “This file is not valid for the Flexmotion board selected”.
However, I went to C:\Program Files\National Instruments\Motion\FlexMotion\bin and deleted 7344.fp2
I then renamed 7344pwm.fp2 to 7344.fp2 and copied it to the “bin” folder, then in MAX I selected new file to download, pointed to 7344.fp2 and successfully download the new firmware to my 7334 motion controller. Now in MAX the FPGA2 firmware version is 5.20.000f.
Unfortunately I c
an still only update the PWM duty-cycle on my 7334 at 3.6 kHz!
Is this correct? do I need to update the file 7334.fp2 instead? or does the file 7344pwm.fp2 also work for the 7334 card?
Also, is it possible to generate a PWM using the stepper motor output in open-loop mode? If so, do you have example code on how this is done?
Thanks again for your help,
Brian
Regards
Ray Farmer
(872 Views)
