08-20-2025 04:21 AM
The LabVIEW roadmap states that "Build, load, and deployment time improvements for PPLs" has been implemented in LabVIEW 2025 Q3. But I don't find information about that in the release note.
Can we get more info about it?
08-20-2025 07:34 AM
You should also check out the LabVIEW 2025Q3 bug fixes. I didn't see anything in there directly with PPLs, but that does not mean things were done that was not publicly documented to help PPLs. But I am with you. NI should answer what improvements were done.
08-20-2025 07:46 PM
Do you have 2025Q3 and are wondering what the changes are, more specifically?
Or are you considering moving to it and want to know if the changes are significant enough to merit the move?
08-21-2025 01:54 AM
Second option 😉
01-22-2026 08:59 AM
I found some information here
Building Applications and PPLs Improvements
LabVIEW 2023 Q3 has improved cache behavior for packed project libraries and applications.The first build will populate the cache, and then the subsequent builds will be much faster.
01-22-2026 06:02 PM
Though I would note that this only addresses the "build" part of the "feature", not the loading/deployment time (is this just in Development? does it affect runtime? what's the scope? etc.)... I have been wondering about this for some time but haven't gotten a response back from anyone on the topic
