PID using formula node, output problem (varying between 0 to the set point)
Hello all;
I am trying to make a PID control in  LabVIEW. my main objective behind this is I need to set my Analog output value to the setpoint I want. (0-5v max) I tried to use LabVIEW paid toolkit but it didn't help me. so I write my own code in formula node, it's trying to set the output, but it's varying from 0 to the set point. anyone can look into my problem and help. my only job is to keep the Analog output voltage to desired set point using PID.
Please see the Attachments.
(2,444 Views)
 I am unsure on what you mean by formula node? Also, which toolkit were you using that did not work for you?
-Brian J.
(2,404 Views)
Accepted by topic author Moonnight786
I recently made a very simple PID VI. The Error Factor is set point - process variable.
(2,401 Views)
Thank you Brian J for your reply, I tried to use Labview PID toolkit,
(2,388 Views)
Thank you so much GREGORYJ, your simple example helped me a lot.
(2,379 Views)
