11-16-2019 12:52 PM
Hi Milon,
@Chowdhury_Milon wrote:
As I said before, after getting the process value (PV) steady state (after 190 s in the picture), I want to stop this code and go to the supply step. How can I go to the supply step by stopping this nutrient solution preparation code?
What about changing that stop condition?
Maybe something like "stop when PV is in valid range for x seconds" - instead of "stop if PV is in valid range"?
11-16-2019 01:16 PM
Mr. GerdW
Yes, I agree with you but the PV setting time is not always the same. I can understand the condition but can't set the proper vi. I tried to use "In Range and Coerce" vi but it is not the proper one. Would you please give some suggestions or show some similar examples?
11-16-2019 03:20 PM
11-17-2019 03:50 AM
Hello Mr. GerdW,
Greetings. I am really sorry, I tried to combine the "In Range and Coerce" with "ElapsedTime" but can't succeed. if you have any idea, would you please share that with me?
Thanks in advance.
11-17-2019 10:30 AM
Hi Milon,
as usual:
What have you tried? Where did you fail?
As said before: the idea is to check for "is in range for a certain amount of time"…
