12-27-2018 07:52 PM
Hi everyone,
For my project, i am trying to build a lab View program to control temperature, pressure and vacuum in single zone and multiple zone furnaces and ovens especially for curing composite materials. I recently learned that PID auto-tuning is not accurate and might create unstable system. Thus, i am trying to implement PID gain schedule for the gain values. I was wondering what will be the best approach to fill gain values table for various temperature and pressure data. Thanks
12-28-2018 02:46 AM
I suggest you to understand how PID tuning works.
Then you can use the method that suite your need.
In my case, I was using the Zeigler-Nichols.
It was more precise than the auto-tuning of LabVIEW.
I was able to control temperature at a precision of 0.001 degC on optical component.
The overshoot was very small and the response quite good to.
Benoit
12-28-2018 08:56 AM
I've used both the advanced and the Smith Predictor auto tuning VIs successfully in past LabVIEW projects.
The auto turning VIs can sometimes provide a quick starting point that can be subsequently fine tuned for faster response, less overshoot, etc.
Playing with the simulated examples is a quick way to try it out.
01-05-2019 07:40 PM
Thank you. I am new to labVIEW and still learning.
