PFI Trigger voltage channel
Hi all,
This is a pretty simple question. For a PFI trigger input on a DAQ card, is there a common maximum voltage that the card can handle? if so what is that voltage?
Thankyou!
(2,412 Views)
Guess what is written in the specifications?
Greetings from Germany
Henrik
LV since v3.1
(2,406 Views)
It is designed to be a 5V ttl or cmos signal.  With a bit of overhead, but i would not repeatedly rely on the card to handle overvoltage.  Put a 5V zener diode across the input (and a series resistor to drop the current).  That can protect against almost anything for a few pennies.  If you get to kV there are other things to prevent arcing.
For a few hundred volts, a 10KΩ resistor and 5V zener for a fraction of a watt will solve the issue and protect your hardware cheaply.
LabVIEW ChampionLabVIEW Channel Wires
(2,264 Views)
