09-24-2014 09:39 PM - edited 09-24-2014 09:49 PM
Hi all!!
Please help me!! the PF4000 or PF3000 have Open Protocol ethernet, I try connect LabVIEW Between PF3000 or PF4000, but I Can´t.
I have the Data that I need send MID 0001 to get communication with device, but the Device not respont, I write like this "MID 0001" , the manual said " The Integrator Send MID 0001 Communication start and the Controller answer MID 0002 Communication start acknowledge" but the controller not respons.
I need add something? to message or What I need doing?
I attached the file where description the OPEN PROTOCOL.
Please help me!!! I will crasy.
If you have some examples, please send me one
Thanks for all
Best regards
09-26-2014 03:52 PM
Hello qz6y7q,
Thanks for using the National Instruments Discussion Forums, can you share with us your VI to see how are you trying to communicate?
Have you tried to do a ping to the protocol server?
Best regards.
12-01-2014 07:19 AM
Hello!
I happen to have an implemented VIs for Open Protocol for Desoutter CVIR2 - but as far as I know, OP is completely universal in terms of device, so you won't probably need any modifications.
Please PM me for the code.
08-20-2016 01:40 AM
sir can u send me the sample vi .how to read and send commands to the controller
EMAILID :hvijaycbe@gmail.com
08-20-2016 01:43 AM
sir can u send me the sample vi.how to read and write commands to the controller
emailid:hvijaycbe@gmail.com
03-31-2017 07:22 AM
Could you just ping me the code for extracting the data from the power focus controller using this open protocol ?
03-31-2017 07:24 AM
Could I just have your code for extracting information through this open protocol ?
07-20-2018 08:43 AM
Sorry I realize this is an old thread but do you still have this code that you could share?
10-29-2018 05:07 PM
Hi please can i get the labview codefor open protocol aswell. Id really appreciate it
10-29-2018 07:15 PM
Sorry I was never able to get this code. We ended up using ToolNet8 a database software from Atlas and pulling the data out of a SQL database. If you come across this code let me know.
