PCie 7852R - Multi-Element Access on Target: not Supported - what its mean ?
hello , i am try to understand what it is mean this fact  Multi-Element Access on Target: not Supported.
Is it possible that two pulses from the same DMA cannot be detected simultaneously?
thanks
(786 Views)
I have found a couple of discussions about this topic:
Hope this helps!
Alessia
(747 Views)
You can interleave data on a single DMA channel. Detecting could also happen on the FPGA
From the comment it isn't really clear what you want to do.
ALE Consultants
(738 Views)
