Hi:
I want to simultaneously port0,pot1,port2,I use PCI 6225,but when I use DAQ Assistant to build a task, it display me:
For example I want to write port0-1,3,port1-2,5,port2-4,6,how to configure in LABView 8 ?
Error -201062 occurred at DAQ Assistant
Possible Reason(s):
Selected lines do not support buffered operations.
Ensure only lines that support buffered operations are being used in the task. If using change detection, the task must be changed to non-buffered hardware timed single point to support these lines.
Thanks a lot
maincool
