PCI-6542 card for dynamic genration and static control
Hello
I am using only one PCI -6542 card. I want to use few channels for dynamic signal. These are control signals for the ADC. While the conversion is in progress I want to use remaining signals for switching relays for measurement.
Application requirements are as follows.
Channel 0-14 are for dynamic genration for giving control signal to ADC.
Channel 15-31 are for static control bits for relays.
Requirement is pattern should be running continiously and parallely I shoud able to switch the ralay. It can be in any order and any seqence as per the demand.
Thanks and Reards
Amol
(2,218 Views)
Hello
I can able to solve this problem. For your referance I have attached here the code. Which works for this.
Thanks and Regards
Amol
(2,207 Views)
