PCAN-USB adapter with NI-CAN
@xaheer wrote:
Hey can you share how you used it for peak system hardware. I am facing problem in sending payload.
You didn't say what you tried, and you didn't say what is the problem.  I've never used PCan hardware but the drivers on LAVA look fine.
Message 11 of 13
(2,185 Views)
i mean to send physical signal into raw signal i am facing problem of unable to convert them into raw signal, Payload is there any way like in NI/xnet they are done automatically.
Message 12 of 13
(2,183 Views)
I have a toolkit here with some demos and example DBCs.
https://forums.ni.com/t5/Example-Code/CAN-Frame-Signal-Conversion/ta-p/3534000
Look at the example which takes in a DBC path.  It then takes the signal names as strings, and their values, and returns the raw frames that can be written.
Message 13 of 13
(2,176 Views)
