08-06-2019 04:29 AM
I am acquiring an analog signal from physical channel A with a frequency f and underlying TimeBase of 100MHz from the DAQ card (internally, i.e. no external trigger source).
On physical channel B I now need to output a digital signal that coincides with the ticks used for the acquisition of channel A.
Specifically, whenever the DAQ board generates a tick to start the acquisition of one sample on channel A, I want that same tick to simultaneoulsy be output on channel B. This means that I do not want to specify a frequency for the output of the ticks on channel B, but rather 'redirect' the tick signal to an output.
I am using the PCIe-6376 card.
The manual states that "AI Sample Clock Timebase is not available as an output on the I/O connector." Does this mean that what I am trying to do is impossible?
Attached is my best attempt, however, I am having trouble getting the ticks to be output on channel B.
08-06-2019 04:47 AM
08-06-2019 04:51 AM - edited 08-06-2019 04:53 AM
I don't have a physical card to check, but I think you should be able to do this (it works with a simulated PCIe-6376)
Here I've used the DAQmx Connect Terminals.vi to route the ai/SampleClock to PFI0, although you can use any of the PFI lines. This allows you to mirror the sample clock to an output line, which I think is what you want?
08-06-2019 04:53 AM
If you can't export the clock you need to a PFI pin on that hardware, you can perhaps still make it work another way.
I think you could generate a 100MHz pulsetrain on a digital output pin (this is the exported clock you need), then route it back in to another digital pin on the hardware and use this as an "external" sample clock for your analog IO.
Deceased
08-06-2019 06:50 AM
@ GerdW:
What yours does, is give a HIGH tick whenever I take a sample, no?
What I need is a HIGH tick whenever the counter for that channel is HIGH. I.e. if I use a 100MHz Timebase for channel A, I want channel B to output a 100MHz signal. The acquisition rate should not affect the output of channel B at all.
08-06-2019 07:27 AM - edited 08-06-2019 07:29 AM
Ah, then for my suggestion you also don't want the sample clock but rather the timebase. Just choose differently from the options.
As a side note, you may need to right click on the control/constant and enable Advanced Terminals via the filtering options. See here for details
08-06-2019 11:03 AM - edited 08-06-2019 11:06 AM
First 2 steps back and hopefully we'll find our way along to 3 steps forward.
1. If you go into MAX and select your device, there's a tab at the bottom for "Device Routes". This is a good place to go when you need to figure out what routing you can and can't do. And sure enough, it's clear that the AI Sample Clock Timebase can't be routed to a PFI pin.
2. Fortunately, while the *functional* signal known as the "/Dev1/ai/SampleClockTimebase" can't be routed from inside the AI timing engine circuitry, the raw original signal outside the AI timing engine *can* be. It's known as "/Dev1/100MHzTimebase".
3. The routing matrix in MAX shows it in yellow on my device, meaning that routing is *indirect*, requiring the use of some further resources on the board (usually a counter).
4. cbutcher has been exactly right, twice. In msg #3 he answered the question as you originally phrased it. In msg #6 he answered your clarified question, telling you more briefly and directly the same thing I'm giving you some background details about.
5. It still seems odd to export the timebase alone. I'd think that at some point it'd be important to *also* establish when the AI samples happen. Exporting clocks is usually for the purpose of syncing separate devices, and syncing usually also means aligning sampled data from those separate devices. I'd think you'd want to also export the AI Sample Clock signal.
-Kevin P
