12-13-2012 11:36 AM
I am trying to generate a sine wave and output it to a PC speaker. It works ok, but I can hear breaks in the sound, perhaps at the end of the sample size. Is there a way to avoid such an issue. Attached is the VI.
Thanks.
Solved! Go to Solution.
12-13-2012 01:07 PM - edited 12-13-2012 01:08 PM
The problem is that you are using an express VI that load a sound, starts generation and at the end stops generation - each time its called. There is also some processing of the data that the express VI redoes each time it's called.
Mike...
12-13-2012 04:27 PM
12-14-2012 07:54 AM
Thanks. I came across this one and used it. It works, but I wasn't sure why the other one didn't work.
