09-08-2011 12:42 PM
I am a student at Nottingham University in the UK. I have been given a PCI-MIO-16XE-10 and a TBX-68 to use for a control project. I know how to get a sine wave produced in Labveiw but how do I output this to my hardware?
I have used Measurement and Automation explorer to output test signals from the test panel and created a task within measurement and automation explorer to output signals. Both work fine, I just need to do the same using LabVeiw.
I know these are quite old pieces of hardware but I guess all I need is the correct block within Labveiw to output to the hardware.
09-10-2011 11:13 AM
I would ask you to have a look at the following tutorial:
Also, if you open up Example Finder (Help -> Find Examples), you should see lots of Analog Generation examples in the directory Hardware Input and Output -> DAQmx
