Out of Memory Error - why?
Win 10, LV2018SP1 (32 bit, stop laughing)
I'm stuck on 32bit for the time being, and am running into the NOT ENOUGH MEMORY TO COMPLETE THIS OPERATION error.
The TASK MANAGER's memory display shows around 3225 Mbytes when that happens.
I know that that is the expected limit, inherited from days of old, and understand that.
In poking around, I ran into one of the larger offenders, and I'm having trouble figuring out why.
This video <https://www.screencast.com/t/B8XEKrdlCR5> shows a breakpoint in one of my classes.
As we start off the memory stands at 998.2 MB.
The PRINTOUT START is an abstract VI, and it is not overridden in this case.
But AS SOON AS I STEP INTO IT (0:10), RAM goes up to 1054.2 MB, an increase of 56.2 MB ! ! !
You can see the code does nothing except pass inputs to outputs.
AS SOON AS I STEP OUT OF IT (0:17) RAM goes up to 1111.0 Mbytes - ANOTHER increase of 54.8 MB ! ! !
When I step into the NEXT method (0:27), RAM goes up to 1225.1 an increase of 114 MB.
Stepping OUT jacks it up to 1394.5
I don't understand how an abstract (no code) method could command over 50 Mbytes.
The CLASS terminals are dynamic, it could conceivably be overridden, but in this case it's not.
You can see that the abstract method is in the SAME PPL as the caller.
That class takes up 1610 KB on disk, and is a child of another class in a 762KB PPL, which is a child of another class in a 54KB PPL.
Altogether that's 2400 K bytes, so how does that get inflated to 56 MBytes?
There are several calls to this class, it looks like each one has an exorbitant cost, both on entry and on exit.
I've tried the DEALLOCATE NOW thingy, to no effect.
Any ideas how to debug this?
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 1 of 11
(2,552 Views)
FYI the link for Screencast you posted includes an unneeded ">" at the end so I had to remove it to watch.  You might want to edit your post to remove it from there.
Can you add code in there to get the approximate size of the data in the object you are using there?  The "MoSAIC Printout" one?  Something like this where it flattens it to a string, then gets the string length:
That won't be the exact size to the byte, but it will get the general order of magnitude and check and see if there's a large amount of data floating around in that object, and if there is it could just be that it's making a lot of copies of that data which end up being expensive in RAM.
Message 2 of 11
(2,533 Views)
My guess would be the same as Kyle's: the object has that data. When you step into the VI, you open the FP, so you will need copies of the data for the input and output controls. I would suggest trying breakpoints before and after without stepping into the VI to see if still behaves the same.
The profile window or the DETT might also help with the analysis.
Also, it's not "deallocate now", but "request deallocation", which has a different meaning (assuming it even does the deallocation).
___________________
Try to take over the world!
Message 3 of 11
(2,487 Views)
Corrected link to video: < https://www.screencast.com/t/B8XEKrdlCR5 >
Steve Bird
Culverson.com
LinkedIn
Message 4 of 11
(2,464 Views)
Steve Bird
Culverson.com
LinkedIn
Message 5 of 11
(2,454 Views)
Hmmm.  I did that and the RAM usage before and after that abstract VI call is exactly the same.
But if I step INTO it, the usage goes up by a lot, and stepping OUT of it makes it go up more, and that does not come back.
I don't understand why - the only controls/indicators on that VI are the class in/out and error in/out.
The class might have a lot of data, so, apparently it has to make a copy when the panel opens (which makes sense), and another copy when it closes (which doesn't)?
And why isn't that ram recoverable?
I still run out of RAM later on, so this is not a solution, just a point of info.
Steve Bird
Culverson.com
LinkedIn
Message 6 of 11
(2,428 Views)
