LabVIEW can't figure magicallly which VIs you'll call dynamically to include them in the application. That is why you have to add them yourself as "Dynamic VI" in the application builder. It is a one time procedure and may be tedious at most but not painful...
When you add a VI as Dynamic VI in the AB, the VI and its subVIs are included in the application internal LLB so you do not have to specify the subVIs in the list.
Labviewguru suggested to include the dynamic VIs on the diagram of a loader VI (set as Dynamic VI in the AB). It is true that all subVIs will be automatically included but you will find the procedure as tedious as selecting them in the AB.
About the Dynamic VI path in a built application, the good news is that you don't have to care
at all. When opening a VI reference from a VI path, the server first looks in the application internal LLB (where are stored dynamic VIs) to search for a VI having the same name. If one is found, the actual path is ignored and the internal VI is opened. Thus you can leave the same path you used in LabVIEW development to build an application calling Dynamic VIs.
Including a LLB as support file won't have any effect on the application. The LLB will simply be copied as is in the destination directory so unless you build dynamic VI paths to this exact location, the VIs won't be found.
Error 7 means that the VI specified in the path was not found neither in memory, in the internal LLB nor at the actual path. Unless I'm mistaken it also occurs when you attempt to open the front panel of a VI which FP hasn't been saved. By default the AB do not save the FP of dynamic VIs, you have to change this setting manually when required.
