Open Specific WorkBook.vi: subVI is not executable error
I think the Vi is the same, but post it anyway just in case...
Daniel Coelho
VISToolkit - http://www.vistoolkit.com - Your Real Virtual Instrument Solution
Controlar - Electronica Industrial e Sistemas, Lda
Message 11 of 24
(3,175 Views)
Message 12 of 24
(3,173 Views)
You gave me the entire example.
Could you post the ExcelExample.llb?
This way I can replace that llb for mine.
Thanks.
Daniel Coelho
Message 13 of 24
(3,169 Views)
What...? I don't have ExcelExample.llb... 😞 but where you want to use it...? Please explain so that it will be easier to help... 🙂
Message 14 of 24
(3,167 Views)
The VI you posted has the entire example on how to open and close the excel file. But my error is on one of the subVIs used on that VI.
The error is on the Open Book subVI.
The VI you posted apears as the printscreen attached.
I could replace the missing subVIs with mine but the problem remains, because the problem is exactly on the Open Book subVI.
What I don't understand is why the Open Specific Book.vi(Open Book) has the error: Invoke node contains unwired or bad terminal.
Daniel Coelho
Message 15 of 24
(3,163 Views)
Accepted by topic author Daniel Coelho
Oops Sorry... here is the all VIs... 🙂
Message 16 of 24
(3,161 Views)
You got the solution or it's still not working... ?
Message 17 of 24
(3,145 Views)
I don't understand why your VIs are working and mine are not. But, YES, it is working.
Please post me all the ExcelExamples VIs or post the 'ExcelExamples.llb' so that I can add them to my labview project.
Because, my project is in conflict with your VIs since they have the same name. If you post the ExcelExamples.llb I'll replace yours for mine and the conflict is gone.
Daniel Coelho
Message 18 of 24
(3,141 Views)
Is it possible for you to provide me your .llb file where you extracted your VIs?
Or at least provide me all the VIs that come with the Open Specific WorkBook.vi, etc...
I'd apreciate it.
Daniel Coelho
Message 19 of 24
(3,132 Views)
Hello... 🙂
         I just extracted open specific workbook.vi....... That I sent you... Now what else you want....?
Message 20 of 24
(3,098 Views)
