03-22-2006 02:26 AM
03-22-2006 05:10 AM
Hii, Khalid
Thanks for the Suggetion man, but it wont work for me, because wehn vi, will initialise, all the graphs, will initialise to the current date and time, but after that only one graph, which is currently update will update the time on x-axis and else othes will not update the time, they will be haulted to the initialised time, now if i ll switch over to another graph in anpther tab, then that graph will start updating the time on X-axis from the initialised time and not from the current time, and the graph from which we have switched over will stop updating the time on X-axis, so it will hault the time on current time, thats why i have to update all the graphs, and talking about history chart, i have to keep this much history because user requires, but i will try to convince the user and to minimize the chart history length. anyways thanks for the valuable input, i hope that this will help me in my other projects.
Nishant
03-22-2006 06:14 AM - edited 03-22-2006 06:14 AM
Nishant,
Please carefully review this article by DF Gray entitled "Managing Large Data Sets in LabVIEW".
http://zone.ni.com/devzone/conceptd.nsf/webmain/6A56C174EABA7BBD86256E58005D9712
The section labled "How to reduce the data used to plot graphs" will help you.
This is very deep info and you may want to read it a couple of times before it all registers.
Ben
Message Edited by Ben on 03-22-2006 06:16 AM
03-22-2006 10:38 PM
Hiii, Ben
Thanks, its a real good document about memory management in LabVIEW, and other than that, this link has left so many other options for managing memory, information about when it is creating new buffer,etc..,
Nishant
04-14-2006 04:32 AM
04-14-2006 12:34 PM
04-14-2006 11:07 PM
Hiii, vivi
i know there are so many property nodesa and globals, but i already had decrease some of that and now it is not possible for me to decrease it anyways, cos it wont give me the output i want, and if i talk about my original output, it is there it is giving me one second of time in one second, but this is the problem of widening the screen of monitor, if screen is 17", should it mean that the procedure one second must complete in 1/2 or 1/3 part? so that it shows the procedure completed in 1 sec in the wide screen?
Nishant
04-15-2006 02:02 AM
Hello Nishant,
By "screen size" are you referring to the diagram size? And wondering if that has an effect on the performance?
-Khalid
04-15-2006 03:01 AM
04-17-2006 02:24 PM
Nishant,
Ceteris paribus -- with everything else being exactly the the same -- just changing the display-size of the chart, slows down the system? Are you sure you're not changing the X-axis' start and end points? Does this happen on a single machine when you stretch the chart?
-Khalid
