From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
Once true in a loop
Dear all
I need to count the times I press the true button for saving data. If I still pressing and the loop time is 1 s it continues counting the true times, but I only need to count once each time I press true button.
I share a small example from my code for better understan.
Please take note my LB is 2013
Best
CPalka
(1,285 Views)
Accepted by topic author cpalka
Hi CPalka,
so you only want to count rising edges?
Use quickdrop to easily place "BooleanCrossing" in your VI…
(1,278 Views)
Hi GerdW
Thanks for the help, it´s working now.
Best regards
CPalka
(1,255 Views)
All you probably need is set the button to latch action. No extra code needed. (right-click...mechanical action ...)
(Also note that counting should be done with integers (blue), not floating point numbers(orange)).
(1,241 Views)
Hi altenbach
I need to save data until  releasing the saving button.
Best
CPalka
(1,130 Views)
Well, you never said that. 😄 I assumes that pressing the button would just add one log entry, for example.
You still don't need all these subVIs and complicated code. Here's how I would count how many times the "switch until released" button went from false to true.
(1,057 Views)
