12-12-2014 01:10 PM
On the block diagram, I clicked EXPRESS - SIGNAL ANALYSIS , then all I get are SIMULATE and HISTOGRAM. What happened to the rest like SPECTRAL, TONE, STATISTICS, etc.?
Solved! Go to Solution.
12-12-2014 01:35 PM
Where they there before? What LabVIEW version do you have (base, full, professional etc.)?
Did you try to repair the LabVIEW installation?
12-12-2014 01:46 PM - edited 12-12-2014 01:47 PM
Thanks for the reply.
We have the Base. Only time I noticed there are other features is when I try to learn the programming from here at 3:18....http://youtu.be/6rdkddXd2Xs
No, haven't done to repair the installation.
12-12-2014 02:28 PM
These tools are only available in the full development system and above. LabVIEW Base does not have much singal processing.
12-12-2014 06:07 PM
Thanks again for clearing that up.
I was assured by Tech that the Basic will allow me to view and collect temperature readings.
Went ahead and used the SIMULATE tool then connected it to the WAVEFORM CHART. I get a sine wave. I was expecting a temperature chart.
Basically, for now, just looking to read the temperature in a graph form.
Any help will be appreciated.
12-12-2014 06:25 PM
(Well, if you get a sine wave, you are probably simulating one. :D)
Where do the temperature readings come from? Please show us your actual VI. This seems almost trivial.
12-23-2014 03:55 PM
12-23-2014 04:05 PM
12-23-2014 04:08 PM
That was my answer to my post 3 messages up.
Sorry, the Statistics issue has already been cleared before that.
Thanks and I appreciate your reply, considering that you guys are always willing to help.
Please consider this inquiry closed.
