From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Omega Flowmeter connection and VI
Im currently working on a project and need help connecting a sensor and creating a VI. I have an Omega FPR135 and NI USB-6001 DAQ. Very new to labview so anything would help.
Message 1 of 8
(1,667 Views)
Hi chealv,
When you are new to LabVIEW then you should start with those Training resources offered at the top of the LabVIEW board…
Then you should learn the DAQmx basics.
And then you should open one of the example VI coming with LabVIEW+DAQmx to learn how to use the counter input of the NI6001.
Then connect your sensor to this counter input (using appropriate signal conditioning!) and count the pulses coming in…
Message 2 of 8
(1,657 Views)
Fairly simple.  You don't even need an additional power supply the 200mA from the 6001 can drive THAT device
  • Connect the red wire to the 6001 5V out
  • Connect a 10kOhm pull-down resistor from PF1 to digital gnd. The 6001's internal 47.5k pull-down is not "stiff" enough for the sensor.
  • Connect the white wire to PF1
  • Connect the black wire to digital gnd
Create a counter task counting positive edges.  Read count. Divide count by 243 to get gallons(US).
If you are in England ....Good luck finding a plumber to work with those .75 inch brass fittings on the sensor. 😀
"Should be" isn't "Is" -Jay
Message 3 of 8
(1,641 Views)
Thank you so much for your response. I was able to get the counter working quite easily using the task. Is there any easy way to copy a task to a labview vi? I couldn't get the continuous_counter.vi sample to work.
Not in the UK but also will not be the one working with brass fittings😋
Message 4 of 8
(1,611 Views)
Accepted by topic author chealy
Why, yes there is an easy way!
Save the task you created with the DAQmx Wizard since it sounds like you got it working.
Open a Blank Vi block diagram and place a DAQmx task constant.  Right click the constant and>>Select the Task you saved by name.
Right click again and select "Generate Code (Configuration and example)"
Watch everything magically "Poof!" into existence.  SMILE and don't tell the boss how easy it was.
Message 5 of 8
(1,604 Views)
Im having an issue to dividing the count by 243 in labview, does labview round up as soon as it reaches 0.5 gallons? Could I also add a timer that so I can get gallons per minute? Any tips for this step?
Message 6 of 8
(1,524 Views)
