I am trying to revitalize an old AT-MIO-16L-9 board. I am using a 486PC
with 32 MByte under Win98 and DAQ 6.1.0 and LabVIEW 4.1.
First of all, I installed the board with the DAQ Configuration Utility
and tested it with the DAQ Test Panel: Everything works fine!
Then I configured the board with the DAQ-Channel-Wizard and tested the
board with the DAQ-Channel-Wizard Test Utility: Still working!
Afterwards, I created a LabVIEW sample program with the Solution Wizard
and also implemented the "Quick-Start" example program. Result: I
measure only zeros!
Any idea of my problem?
Christian Wennmacher
