12-03-2009 09:27 AM
12-03-2009 10:05 AM
Interesting. Here is what I did recently. I have some hacked code that lets me drop snippets into LV8.6 (with the BD in run mode). I was testing it out, but instead of choosing some simple snippet, I accidently dropped some mess with subVIs etc. Working as it should, I got the search dialogs, but I did the usual tap-dance to cancel them. In the end, nothing, and then the black circle. Of course since I was dealing with my own code and hacking Windows, I put the blame squarely on myself. I remember a LV restart was required to set things straight.
This sounds very similar, and I suspect the same effect is in play. You are well aware of the dance that is Windows messages and all of the hooks, callbacks, etc. It appears that LV is not handling that properly, when you cancel, it just drops the ball and tries to move on. Windows, apparently is desperately trying to finish a drop, and won't let you drop something else until the first one is complete.
Now I have just hung my LV9 by canceling a search (from the file browser) during a snippet drop. Thanks alot!
12-03-2009 10:12 AM
I can not exaclt duplicate your test since my LV 2009 machine does not have acces to the net but I saved the snippet to a shared drive and then dragged the down-loaded version into a diagram.
After waiting and hittinf cancel, the diagram and Fp where as expected. I was able to right-click and do "disconnect from type def" on all of them and the VI was runnable.
So try downloading and then do you drag to BD to see if that is a work-around.
Sorry but that's the best i can do.
Ben
12-03-2009 10:30 AM
Well, I have finally fulfilled my purpose in life.
Ben wrote:After waiting and hittinf cancel, the diagram and Fp where as expected. I was able to right-click and do "disconnect from type def" on all of them and the VI was runnable.
That's the thing - it will work as you described sometimes when you cancel through all those file dialogs, but I found that most of the time I see the behavior I had described.
12-03-2009 10:52 AM
Dragging from my server (repeated three times with no errors) does not show any issues on my machine.
Does the same problem occur if you save the snippe to a local drive and THEN drag it into a diagram?
Ben
12-03-2009 11:23 AM - edited 12-03-2009 11:23 AM
Ben wrote:Dragging from my server (repeated three times with no errors) does not show any issues on my machine.
It does not appear to, so far (I also tried it several times as you did). Very interesting...
12-03-2009 11:40 AM
smercurio_fc wrote:...It does not appear to, so far (I also tried it several times as you did). Very interesting...
Message Edited by smercurio_fc on 12-03-2009 11:23 AM
Now couple that observation with your earlier note about the file names ($ signs) and the wierd name mangling of a VI opened from a browser (%20 instead space), so maybe a Windows issue?
Ben
12-03-2009 04:27 PM
