Ocean optics Nirquest512 problem
Hi all,
I’m trying to use Ocean Optics USB4000 and NIRQuest512 spectrometers to measure spectra.
When I set the integration time to 100 ms (100,000 μs), the USB4000 works properly, and the measured values match those obtained with OceanView.
However, when using the NIRQuest512, I encounter several problems:
  • Sometimes I get error 1073807339 (timeout issue) or error 1074001919 (synchronization issue).
  • Other times, I get abnormal readings, where the values measured by LabVIEW are several times higher than those shown in OceanView.
(For reference, the NIRQuest512 works normally when used with OceanView.)
My system setup is:
Windows 7, LabVIEW 2018, Ocean Optics 2000–4000 driver (2018 version).
(523 Views)
Accepted by topic author bingyu
We have used Ocean Optics spectrometers at our company for quite a while.  We also used those same drivers (and in many cases, still do).  We also got those same errors.
Best we could ever do was put all the code in the main "read spectrum" VI in a FOR loop with the following conditions:
Number of loops = 2 or 3 (configurable)
End loop condition = No error
If error was detected at end of loop and there were still loops left in the FOR loop, clear the error, re-run the Initialize VI, then return to the start of the loop
I suspect that the Ocean Optics folks have either fixed their internal software to not have these problems or have just set it to ignore errors, but never updated their LabVIEW code to do the same.
Going forwards that's the best suggestion I have if you insist on sticking with the drivers you use now.  If you're willing to do a rewrite (and possibly an OS update, I don't think Win 7 will work with it), then look into their "OceanDirect" API.  It's a .NET DLL that LabVIEW can interface with.  I've got it working with just one spectrometer so far and have not nearly the same amount of silly errors that their LabVIEW drivers have sometimes had, but I've only used it briefly.
The downside is that you do need to contact them directly to get it as they don't have a free download on their site for it.  As far as I know, as long as you can prove you bought a spectrometer from them they will send it to you for free, but if you're a 3rd party wanting to use it then there is a charge.  I didn't deal with them directly though (manager did it for me) so there might be a bit more to it than that.
(473 Views)
Thanks for your reply! I’ll go ahead and apply for the "OceanDirect"  API.
(450 Views)
