OS and Network Services: (Hex 0x8ABC7009) Object already exists.
I'm trying to deploy my shared variables library to a cRIO target and I'm getting "OS and Network Services: (Hex 0x8ABC7009) Object already exists." and 'Deployment is completed with errors'. Now I can't run my VI. Anybody knows what this mean and how to fix it?
(756 Views)
Hi macolit,
Have you tried removing the cRIO from the LabVIEW project, and re-adding the cRIO target in FPGA Interface mode?
Was the cRIO used before in any application? Perhaps there is another VI that is causing the problem.
Regards!
(722 Views)
Hi jesicadiaz,
Thanks for replying. Unfortunately adding and re-adding the cRIO target did not solve the issue..I think it has something to do with what has been deployed to the cRIO and it's causing "Object already exists" error. Still investigating. will update this thread when I find an answer.
(692 Views)
